Home > Td5 > Another dead alternator
excossack
Alternator packed in again. Old one lasted from July 2020 to this weekend Sad
New alty to be ordered on order.
The suggestion from Mrs Excossack was, is it due to the extra batteries I have that are charged via a simple relay split charger setup
Do I need a more advanced one?
I did look at this type https://www.ebay.co.uk/itm/331147338969 which looks like heavy duty relay and a pair of volt meters.
Or is it just pot luck?
No oil leaking from the current (no pun) alternator.
Why do they die? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #971009 13th Nov 2022 6:43pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
What has died in alternator?
More batteries is not a problem. Compare charging current with current used by a winch.
I have the same simple system for two batteries. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #971011 13th Nov 2022 6:55pm
excossack
Hi Tom
Alternator is outputting 12.1v or there abouts Sad
I did get a brief 5 mins or so charging but soon returned to battery not charging warning light. 1999 Defender TD5 110
Regards
John M0VAZ
Post #971012 13th Nov 2022 7:21pm
geobloke
Is it only ever charging at 12.1v?
Miffy's will vary between 12.4-14v depending on battery condition and use. What I have noticed is that since fitting LED lights the amount of charge being supplied by the alternator has been much much lower than with all filament and halogen bulbs were fitted.
The only time the alternator really kicks out voltage is when the Waeco fridge is being used or the winch.
Just wondering if since fitting the LED lights the vehicle is now more electrically efficient...
Might be worth taking the alternator to be tested, someone like this - https://www.alternatorsnorthwest.com - Never used them but might be worth giving them or someone closer to you a call.
Post #971084 14th Nov 2022 10:59am
excossack
Previously the voltage has been 13.x Volts upto 14.3 Volts or thereabouts
But with the battery warning light being on and the head lights getting dim....something was not happy.
We have a auto spark place up the road from me who I have used before.
Now I have two dead alternators. I might take one apart for a look. 1999 Defender TD5 110
Regards
John M0VAZ
Post #971087 14th Nov 2022 11:10am
geobloke
Very strange to have gone through two in so short a period. What brand were they?
Post #971088 14th Nov 2022 11:23am
excossack
It is odd.
It could be previous oil leaks getting in to the alternator, it could be unlucky. Denso is the make I have used. 1999 Defender TD5 110
Regards
John M0VAZ
Post #971091 14th Nov 2022 11:30am
geobloke
Huh a Denso... Best manufacturer by far. Weird. I would take it apart and have a look. See if it is just oil contamination.
Post #971092 14th Nov 2022 11:32am
excossack
I will take it apart. I always held them in the 'good make' department 1999 Defender TD5 110
Regards
John M0VAZ
Post #971093 14th Nov 2022 11:35am
excossack
Alty arrived this morning, and I had a 1 hr gap for lunch before another meeting.
55mins later all back together and normal volts resumed. Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #971334 16th Nov 2022 2:08pm
freddie206
United Kingdom 2006 Defender 110 Td5 HT Belize Green
I’d be interested to know why the alternator failed if you end up taking it apart.
I had to replace mine the other day. Granted it was 16 years old but the engines only done 50,000.
Is it just the 4 bolts holding the vacuum pump to the alternator? I have a look at mine later.
Fred
Post #971345 16th Nov 2022 3:13pm
excossack
i will be interested as well.
I think its 4 screws/bolts holding the vac pump in place. 1999 Defender TD5 110
Regards
John M0VAZ
Post #971347 16th Nov 2022 3:19pm
roel
This is the interesting part:
I tried to find this part separate but I failed. Roel
2003 90 Td5 (2009-now)
Post #971360 16th Nov 2022 6:07pm
MadTom
There are 3 parts - regulator, - bushes in holder and - rectifier block. Lot if time the bushes are worn, but it is possible to buy them. And it is cheap. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #971365 16th Nov 2022 7:53pm
lightning
Mine's on 146,000 and still the original alternator.
But the one on our 90 failed at 104,000.
Post #971413 17th Nov 2022 8:35am
