Home > Puma (Tdci) > Puma Red rear engine bracket.
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
As it is really hard to see and get to, does anyone know what size/type bolt holds it in?
It is quite hard to access and I cannot get any spanner/sockets on it. Mine has come loose and vibrates at 2,500 rmp......
 Cheers Don.
Post #970957 13th Nov 2022 11:23am
landy andy
I thought they were supposed to be removed by the dealer, before buyer collected the vehicle.
Sorry can’t help with spanner size, but they are know to vibrate loose, snap, damage hose, and loose their bolts.
Post #970958 13th Nov 2022 12:00pm
They had a habit of working loose and doing what yours is doing, or due to shoddy build control chafing through the ECM harness and stopping the engine (or igniting the vehicle). Landrover's genius low-cost solution was to tell dealers to remove them.
I have always felt that they should be left fitted, after all if you need to remove the engine it is a distinct advantage to have the correct bracket (and you paid for it, so removing it is rather naughty of LR).
As far as I recall the bolts are the same size as those for the front bracket, which are M8 flange head. The fact that they are flange head means that the hex is smaller than the standard 10mm for an M8, probably 8mm AF.
Perhaps I've been lucky, mine wasn't stolen removed by the dealer and has never come loose. It did start chafing through the engine harness but it was no worse than the other seven places that the harness was chafing and at least, unlike down by the turbo actuator and at the top front of the engine, there was no copper showing through. The scary chafe was the main feed from the alternator to the battery, which was showing bare copper when flexed. How that didn't set the car on fire I do not know.
Desperately sloppy build control, very sad how little care LR showed towards the end.
Post #970961 13th Nov 2022 12:47pm
Really, you've heard of one snapping? Tell me more....
Post #970962 13th Nov 2022 12:48pm
landy andy
Why?
Post #971038 13th Nov 2022 9:31pm
I don't understand what would cause an engine lifting bracket to snap.
Post #971039 13th Nov 2022 9:43pm
landy andy
I don’t either. Assume vibration.
Broken bracket here.
https://www.defender2.net/forum/topic63360...ne+bracket
Post #971063 14th Nov 2022 8:05am
Thank you, I'd forgotten that thread. Thumbs Up
I suspect that the top bolt fell out and vibration did the rest, but as you say, they can definitely fracture!
Post #971076 14th Nov 2022 9:52am
