Home > Puma (Tdci) > Going from TD5 to Puma
Page 2 of 3 <123>
markb110
VED is higher isn’t it…?
Post #970739 11th Nov 2022 11:25am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Just looking at insurance quotes and the particular Landy I’m looking at comes up as “Heavy Duty”
“LAND ROVER DEFENDER HARD TOP 90 HEAVY DUTY”
None of my others have ever been described this way?
Any ideas?
Jim
Post #970741 11th Nov 2022 11:33am
jim4244
£290 per year
Jim
Post #970742 11th Nov 2022 11:35am
ibexman
I must say I liked the dash in my then new 2007 puma didn’t like 1st gear . I went back to td5 in 2009 and have remap v8 5th gear 1.2 transfer with ATB An arb diffs it’s as good adit gets will cruise at 75 all day regards Chris
Post #970743 11th Nov 2022 11:58am
markb110
jim4244 wrote:
£290 per year
Jim
Thats ok Jim, some are eyewatering these days and expect them to go up again at the next budget.
Interested in the Heavey Duty description. My HT doesn't say that
Thumbs Up
Post #970748 11th Nov 2022 12:50pm
landy andy
My late Td5 is £560 per year road license. Costly, but still only just over £10 per week, and then I’ve got the best vehicle Whistle Whistle
Post #970750 11th Nov 2022 1:03pm
Dinnu wrote:
Regarding the 1st gear being so low, is it not better to have it and don't use it rather than not have it and need it? Like wise with 6th.
Of course can argue that can use the transfer box, but try to shift the transfer case at any speed higher than almost 0 speed.
It is much easier to change from 2nd to 1st or vv. on the move in a Puma than it is to change from 1st high to 2nd low or vv. in a TD5. Additionally the superior torque profile of a (stock) Puma makes it less likely to be necessary than that of a (stock) TD5 which has nothing like the low-speed torque of the TD5.
The TD5 is undoubtedly a more refined engine than the TDCi, and ultimately the choice of which is "best" and which you prefer is a very personal choice. As a general rule (and as a general rule there will without doubt be exceptions) if cars - especially modern ones - and other SUVs are your background, you are likely to find the TD5 more to your taste as an engine. If HGVs and working trucks are your background you're likely to favour the TDCi. If you want a leisure vehicle the TD5 is more likely to float your boat, if you want a working tool the TDCi probably will.
The interior, and the overall driving experience, of the TDCi is better than the TD5. Your second row passengers in a 110 are more likely to survive and accident in a TDCi (I have no idea how LR were allowed to fit seats without head restraints in vehicles as late as 2007).
Your driveline will last longer in a TD5 probably because the engine is smoother and has less low-down torque.
The only way to decide what is best for you is to drive both and make up your own mind.
Comments like this:
ibexman wrote:
Td5 was the last REAL Land Rover Why would you put a ford transit engine in a Land Rover 🙈
... whilst undoubtedly the sentiment of many are generally not helpful towards making your mind up (my personal opinion is that the last REAL Land-Rover was the SII because it was the last to have no significant plastic components) and it has to said lots of folk were putting Ford engines (Dagenham or Cologne V6s usually) into Land-Rovers by choice long before Ford started putting Ford engines in Land-Rovers. WHy would you put a Ford engine in a Land-Rover? Because it is a "better" engine!
Post #970756 11th Nov 2022 2:56pm
Retroanaconda wrote:
... All the Tdci vehicles I’ve drive have had awful gear changes...
Curiously I have only once met a TD5 with a half-decent R380, one of the world's least nice gearboxes. I have never (yet) met an MT82 which hasn't been an order of magnitude superior in almost every respect.
Which I guess goes to show that there are good and bad examples of both.
Post #970758 11th Nov 2022 2:59pm
Any ideas?
Jim
Probably built with HD suspension or a heavier-than-standard MAM. What are the plated weights for the vehicle?
Post #970759 11th Nov 2022 3:00pm
Mother superior
I don't know what flavor of gearbox is in a D2 TD5 but mine was a pig until she had warmed up. Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #970761 11th Nov 2022 3:05pm
jim4244
Is the corrosion protection any better on the Defenders fitted with the Puma engine?
Jim
Post #970763 11th Nov 2022 3:18pm
That would be an R380, same as the TD5 Defender. Not an unusual characteristic and not at all endearing. It can be mitigated sometimes by changing the oil.
Post #970765 11th Nov 2022 3:26pm
Jim
No, it got worse as Land-Rover's interest in the vehicle decreased, as, arguably, did build quality.
One of the undeniable disappointments with the Puma-engined Defenders was the fact that the engine installation design was low-budget engineering, by which I mean that the minimum of related work was done. The result was the inadequate adaptor shaft coupling design, the transfer box lubrication problems of the early vehicles, the fragile fuel system, the inadequate front diff, the sump which could be ripped open by the front propshaft, and one or two other things which should have been discovered and fixed before the vehicle entered production. Most of these were never fixed, and were left to the vehicles' owners to fix.
Post #970766 11th Nov 2022 3:26pm
Mother superior
Can't argue with that. There is a certain feeling of "this engine will not go in this car" "just pop it in anyway, there's a good chap" about late Defenders Oh woe, oh woe
It will not go.
Post #970768 11th Nov 2022 3:36pm
Racedriver
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
In my humble opinion (and I have had a LOT of different Land Rovers), the TD5 is less likely to throw a wobbly and go into limp home mode plus is no more thirsty than a TDCi. However, the better gear ratios and heater make a TDCi a nicer place to sit as a family wagon, especially for those not getting the enjoyment of driving.
Post #970770 11th Nov 2022 3:40pm
Page 2 of 3 <123>
