Home > Technical > Fuel filter changing 2.4 Puma |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
I couldn't afford to lose the brains of the outfit.....: 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
28th Dec 2018 3:34pm |
I've changed it a few times just filling it up but it certainly doesn't give me a warm fuzzy feeling.
I don't have a bleed tool and haven't yet needed one. On other vehicles without a lift pump (or when the manual actuator for the lift pump has packed up) I've put a rag over the fuel filler and blown compressed air in. Ideally you need two people, one to loosen a bleed nipple at the engine end and tell you when diesel is dribbling on the floor. The air supply on a Fendt is worth its weight in gold when you can't get the beet cleaner started |
30th Dec 2018 9:15pm |
