Home > Technical > 2nd Row Door Water Shedders |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Afternoon,
Hoping someone with a late Td5 or TDCI could confirm for me where all of the water shedder sheets go on the second row doors please? From what i can work out from the parts diagrams there are three 'water sheddders' for each door: https://www.lrworkshop.com/diagrams/land-r...mbly_44875 Item 3: (ELD500400/410) which is the main door shedder which is a similar shape/size to the door cards. I have these. Item 13: (ELD000100/110) which look similar to item 14 but have two strips of adhesive. I have no idea where these go but as they are listed for vehicles with central locking i suspect they might go over the locking solenoids? Item 14: (EJD500010) which is the same as the ones for the front doors and somehow hangs over the main door latch unit i think. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
4th Nov 2022 3:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17470 |
It's always cracked me up that they call Item 3 a "water shedder" since all it seems to do, in my experience, is direct any water in the door into the door check mechanism and hence all over the rear mats in the second row footwell.
In the end I became so fed up with regular puddles in the back that that I made my own, conventional style water shedders with heavy duty polythene sheet that direct the water into the drain holes and hence out of the vehicle. I suppose the originals do shed water, but only Land-Rover could come up with the idea of shedding it inside the vehicle! |
4th Nov 2022 4:39pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 201 |
donmacn, has a great bit in his build thread about water shedders. 7th Post down on the page below.
https://www.defender2.net/forum/topic58538-90.html Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
4th Nov 2022 5:08pm |
Excellent cheers all, those photos of Don's have answered some other questions for me too!
Certainly not going to waste money buying the ELD0000100/110 shedders as they are quite expensive for a bit of plastic. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
5th Nov 2022 4:27pm |
