Home > Puma (Tdci) > Transmission whine in 5th and 6th gear
Page 2 of 3 <123>
hjellemorten
Norway 2007 Defender 90 Puma 2.4 HT Rimini Red
Hello, any findings? Have a very similar noise🤔.
Post #969961 4th Nov 2022 5:56pm
pedrocandrade
Brazil 2011 Defender 110 Puma 2.4 SW Epsom Green
No solution so far. The transfer box had two bad bearings. We replaced them but the whine continued. We now opened the gearbox. It appears to be in very good condition. Gears look good and we haven't found a bad bearing yet, but we're looking. We did notice that the car had been using the wrong oil (it was using transfer box oil) in the gearbox for about a month. But the noise precedes that change. One hypothesis that we are considering is that it was running on very old oil before, and wrong oil lately, thus being noisy all the same. There were no signs of wear on the oil replaced before and no sign of wear on the current oil.
There are a few bearings that we haven't gotten to yet, so there's hope that we'll find a clear culprit. The noise appears too loud to me to be caused by a wrong oil on still good gears and bearings.
I'll report back.
Post #969976 4th Nov 2022 8:49pm
hjellemorten
Interesting, very much appreciated. Looking forward to hear more 😊.
Post #970035 5th Nov 2022 4:05pm
pedrocandrade
No fault was found in the gearbox. Gears and bearings look perfect. We put it back in the car, put the right oil in and the noise is still there, in all its glory. We now got a used gearbox + transfer box combo to test in the car. We'll start with the transfer box and if it doesn't change things, swap the gearbox as well.
We'll find the gremlin sooner or later.
Post #970638 10th Nov 2022 3:39pm
hjellemorten
Very impressed with your enthusiasm 😎. Very interesting to follow you.
Post #970641 10th Nov 2022 3:45pm
Dinnu
Fyi, I had a ‘whine’ for as long as I had the MY88 90.
Only recently found that the whine was coming from the shoes gently pushing sideways against the handbrake drum. Was caused my a bolt from the adjuster coming off. But later handbrake mechanism is different from earlier design. But just a thought. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #970657 10th Nov 2022 6:06pm
pedrocandrade
Thanks for your suggestion, Dinnu! We are thinking it’s something in the transfer case or before it because the noise happens similarly in low range and long range, in 4th, 5th and 6th gears. If it were something in the handbrake or beyond it, it would be proportional to the speed of the car.
Post #970931 12th Nov 2022 9:33pm
Co1
Do you get it with the transfer box in neutral and moving up through the gears?
Post #970942 13th Nov 2022 8:15am
pedrocandrade
No. With the transfer case in neutral the whine doesn’t appear. We don’t know whether that’s because the problem is in the transfer case or simply because there’s no significant torque applied to the gears and bearings when we run the gearbox that way. We’ll find out when we swap out the transfer case with a used one soon.
Post #970959 13th Nov 2022 1:07pm
The most common source of a mid-vehicle transmission whine is the small taper-roller bearings on the transfer box intermediate shaft, but it is hard to explain why you're only getting it in 5th and 6th in that case.
(Edited to correct needle-roller bearings to taper-roller bearings - they haven't been needle-rollers since Series days).
Post #970964 13th Nov 2022 1:50pm
pedrocandrade
Thanks, blackwolf! We inspected the transfer box before and replaced two bad bearings, although not that one specifically. We’ll now swap the box completely with a used one to see if the whine disappears. If so, we’ll probably inspect the original one again. I’ll post the findings.
Post #971051 14th Nov 2022 2:03am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
I’ll wait for the gearbox experts to shoot me down but a few years ago I had a noisy R380 box on a 300Tdi 90. I changed the oil (which was in good order) and refilled with new oil that was well over engineered for the box. The whine remained.
I mentioned the whine to a chap who ran his own garage and he suggested a bottle of Lucas Transmission Fix. Now I thought that this was only for automatics but gave it a try anyway.
Whine disappeared and the gear change improved no end. Ran the Landy for another 2 years without problem and in relative silence…
Jim
Post #971125 14th Nov 2022 5:43pm
pedrocandrade
PLOT TWIST
As I said before, we found a used gearbox and transfer case to test on the Defender to help isolate the whine. Well, we have now run it in three configurations:
1) Original gearbox and original transfer case -> whiny
2) Original gearbox and used transfer case -> ALSO whiny
3) Used gearbox and original transfer case -> you guessed it, whiny as well
The sound is exactly the same. I have a real trouble now finding another hypothesis. Sure, it could be that the used replacements have the exact same issue as the original, but since this seems to be a rare problem, I doubt it.
Any other thoughts are greatly appreciated.
Just a reminder, the whine happens in low range and high range in 4th, 5th, and 6th, growing in intensity. It does not appear to be something after the transfer case (like a differential) because it is not proportional to the speed of the car, but instead to the speed of the output of the gearbox.
Post #971648 18th Nov 2022 10:47pm
htb2
Wales
Might as well try the 4th option used gearbox and used transfer box and go the whole hog of options.[/list]
Post #971650 18th Nov 2022 10:57pm
pedrocandrade
We finally got rid of the problem with another used transfer box. Gearbox was not the issue. It’s something inside the transfer box that we were not able to identify on inspection. The fact that it is audible only on 4th, 5th and 6th appears to be simply related to the input speed to the transfer box. We’ll keep this transfer box in the car and inspect the defective one once again to try to fix it.
I’m happy to see this saga come to a close. I hope this record will be helpful to others.
Post #973018 1st Dec 2022 12:02am
Page 2 of 3 <123>
