Home > Maintenance & Modifications > Screen washer system |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 623 |
You’ll have to take the dash out, the rear of the washer jet is obscured by the bulkhead bar and vents etc so It would be hard to access it through the centre dash. Photo shows elderly Puma with dash and vents removed if it helps (fingers crossed bulkhead isn’t like that one, which looked excellent from the outside!)
Click image to enlarge |
23rd Jan 2022 2:13pm |
Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155 |
So according to the instruction manual, removing the panel/console involves 23 steps including…
- remove floor console - remove H/L gear selector - remove gewr shift - remove steering wheel - remove hand break - remove transmission panel - remove instrument cluster - remove steering column shrouds - remove multi function switch assembly - remove instrument panel console - remove passenger grab handle - remove side demister vents - remove panel speakers - release climate control switch panel - release instrument panel - remove console / fascia w someone assistance I am shocked !!! Doing a clutch change can’t be taking more time than that !! And that’s not even getting the reservoir out ! Please tell me there’s an alternative ? |
23rd Jan 2022 2:15pm |
dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 90 |
No need to remove the complete dash!!
Just take out the radio, with a little luck you can see the hose. It’s behind the metal strip on the bulkhead, where the back of the radio gets hold. If you can’t see where the hose is disconnected, remove the middle fascia, remove the metal strip and you can see the the washer jet and the hose. Sometimes if you turn the washer jet, the hose will turn too and the water will no longer get through it. Have a look here https://www.defender2.net/forum/topic61244...p;start=15 Or here https://www.defender2.net/forum/topic50670...p;start=45 Hope that helps Tom Defender 90 XS, 10-2015, Corris grey |
23rd Jan 2022 4:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
You may have disconnected it at the non return valve. Where abouts does the water appear?
23rd Jan 2022 5:59pm |
Dotom it’s perfect. Exactly what I needed. The hose was disconnected from the jet inlet. The fluid was effectively squirting all over the dash. I am lucky it doesn’t seem to have hit any electrical connection.
It’s now all fixed and I didn’t have to remove the whole console; just the middle fascia and the radio. PFEW life saver ! Thank you guys for the (as usual) invaluable help !! Next week end’s job will be to remove the reservoir and clean it properly to remove all debris left in it. |
23rd Jan 2022 6:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
You'll need to remove the n/s headlight to get access to the reservoir and (if it's a 2.4, not sure about the 2.2) unbolt the PAS reservoir and move it aside. The screenwasher reservoir can be coaxed out past the induction hoses.
To clean it, add a handful of pea-gravel and shake vigorously, repeat until clean, the empty out the gravel and flush. Refitting is the reverse of the removal procedure. |
23rd Jan 2022 10:38pm |
Thanks Blackwolf !
24th Jan 2022 10:25am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3676 |
Uncooked rice is quicker!! Gets into the nooks and crannies faster! |
24th Jan 2022 6:49pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
Don’t want to start a new thread…
Is it actually possible to replace the washer pump without removing the reservoir i.e. via the near side headlamp aperture (headlamp removed of course). If so, do the pumps simply ‘click’ in as I can’t see how they actually seal against the reservoir. Thanks in advance |
24th Oct 2022 7:25pm |
Yes it is, yes they click in, there is a rubber seal round the spigot, but they are a very tight fit and it isn't particularly easy.
24th Oct 2022 8:03pm |
Thank you Blackwolf 👍
I was hoping that was the case. |
24th Oct 2022 9:04pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
You could chuck a Milton tablet in the reservoir, leave it overnight and drain. This might dissolve all the scum.
24th Oct 2022 9:22pm |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 183 |
If you are going that far ie strip down, you might as well go the whole way and install the Optimill system, not cheap but a revelation
https://www.optimill-uk.com/washer-jet-systems-td5-tdci.html |
25th Oct 2022 8:57am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
I’ve found a good solution to keeping the screenwash lines clear and without issues with the system is number one make sure that anything that goes in is clean, clean, clean.
After that, it’s not very often you need to change the washer jets front or rear but eventually you will. During the process, with the pipe off the rear of the washer get put it in a container and run the entire or ideally 1/4 of the washer bottle through until completely empty. That way, any small debris in the bottom of the reservoir will go straight out of the pipe. Just using water in the resinous is ideal and chose when your standard fluid is low as you don’t want to waste costly screenwash. Any slightest debris can get stuck behind the washer jets, and reduce their performance. I wouldn’t go out of your way to do this, but worth doing if ever you do change the washer jets. But overall the moral of the story is make sure whatever goes in is always clean, if you use any containers double swill and wash them out with clean tape water not once but twice. You’d be surprised what debris can build up even in the bottle of washer fluid containers for refilling. Everyone does theirs difference, some use pre mix others make up their own. I used to use Motul Apple and mix that, but now I use Rain X pre mix 5L which I’m very happy with. (You can get it from Halfords in store). $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
25th Oct 2022 8:32pm |
