- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
markb110
21st Oct 2022 7:29pm |
Screbble
Thanks for the idea 👍
Alas I’ve cut the T Max brass threaded connector off already and fitted the PCL air chuck
It was the godawful brass connector that was the start of the ‘issue’ as it was just too fiddly and you’d lose half the air when disconnecting.
I then had the PCL tyre inflator donated which dazzled me and set me off on a tangent due to its shininess
I think I’m back on track now.
Thanks for all the suggestions
21st Oct 2022 8:32pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
