Home > Technical > ATB Transfercase
LJMARSDEN
United Kingdom 2006 Defender 90 Td5 HT Java Black
ATB Transfercase
Had my first test drive in the build last night and when manoeuvring it through the unit and out I noticed the inside rear wheel was hopping/ skipping.
Will this be down the nature of the torque biasing diff in the TC or do I have the diff locked without me knowing? 4.0 V8 Defender 90
My Instagram
Post #967306 11th Oct 2022 7:33am
LR90XS2011
was it stuck in transfer box diff lock? ATB should not cause this DEFENDER 90 TDCI XS,
Post #967308 11th Oct 2022 7:46am
LJMARSDEN
Potentially then, whats the best way to check - lift the car off the ground and try and "hold" a wheel? 4.0 V8 Defender 90
My Instagram
Post #967309 11th Oct 2022 7:52am
LR90XS2011
yes
1 apply hand brake
2 gearbox in neutral
3 jack just 1 front wheel so it is just clear of the ground
4 try to rotate the front wheel
if it rotates the transfer box is not locked
if it wont rotate more than a few degrees it is locked
think that is right others should confirm DEFENDER 90 TDCI XS,
Post #967312 11th Oct 2022 8:33am
LJMARSDEN
Brilliant mate, I'll give this a go tonight Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #967313 11th Oct 2022 8:34am
Dtes
1984 Defender 90 Td5 HT Firenze Red
LR90XS2011 wrote:
yes
1 apply hand brake
Thats right
Post #967827 16th Oct 2022 11:04am
LR90XS2011
Thumbs Up DEFENDER 90 TDCI XS,
Post #967830 16th Oct 2022 11:12am
