Home > Puma (Tdci) > LTB00585 Difficulty Selecting Gears/Poor Gear Shift Quality
Page 4 of 5 <12345>
Does anyone have the P/N for the hi / low. Plastic 'tripod' cover?
The P/N I've found before appears to show no suppliers for the P/N that comes up for it.
Last time I looked at mine a few years ago it was broken and would not locate well, how I do not know and I certainly was not the one not who broke it! I had to use a little silicone to keep it in place then at the time because I couldn't find the replacement part needed and had to put it back together asap.
Is it only available with a complete assembly or am I missing something? Chillin In The Backwoods🇬🇧🇺🇸
Post #776777 9th Jun 2019 12:20am
UCB500150 although some parts suppliers give a very odd and misleading description (child seat bracket Shocked )
https://www.lrworkshop.com/diagrams/land-r...ange_45150
Post #776780 9th Jun 2019 7:28am
Thank-you. Yes, that was what I found with that part number. In the end I couldn’t find the actual part anywhere, admittedly I haven’t looked in every nook and cranny on the net but a basic search proved fruitless.
Might have to Ask Dan @ Duckworth parts for info Monday. Chillin In The Backwoods🇬🇧🇺🇸
Post #776793 9th Jun 2019 11:18am
Update, Dan managed to track the part down. I'm not sure what exact P/N, likely the same one as above.
The description is however, very confusing. No idea why that might be.
Price is around £10 not too bad, it's rather annoying how someone managed to break it though when it needn't have been.
Dan has always been successful finding these things that I haven't and always been upmost reliable.
Highly recommended if you are looking for Genuine parts. Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #777147 11th Jun 2019 9:40pm
Slightly Off Topic here but the part I mentioned above arrived.
It certainly looks correct, in fact I’m sure it is.
Curiously, looking at the label it still mentions Child seat adaptor or similar.
I can only but assume it may be a dual purpose part.
I’ve got the WSM paperwork and the spacers now as well.
So when I get around to it I think I’ll use a liberal coating of White Lithium spray grease on the assemble as the manual suggests. Chillin In The Backwoods🇬🇧🇺🇸
Post #778963 25th Jun 2019 4:07pm
jst
just put gearbox back in the 130 and selection is harder than it should be, esp to 3rd. in fact it doesn't return to centre in neutral if i tighten the torex screws right down on the gearstick. my 11plate doesn't have these fitted. what are they doing exactly, stopping the diagonal torex from torqueing down too far when they hit the insert? thus reducing the preload on the ball joint? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #866812 11th Nov 2020 7:08pm
I think they just limit the lateral movement of the lever housing, that's all. In theory you need to use a locating device when refitting the lever, although I've never found it necessary.
Post #866814 11th Nov 2020 7:31pm
jst
maybe thats where i am going wrong, locating device when fitting lever in the ball socket or when fitting the housing to the gearbox? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #866820 11th Nov 2020 7:43pm
Housing to box. The tool holds the gear lever in the correct position to align the housing on the box as the bolts are tightened. I usually pinch up the housing, check for gear selection, and adjust and repeat as necessary until everything feels good, and have never had a problem. Screenshot of the WSM below:
The tools is simply a plastic thing that clips round the base of the gear lever:
Post #866826 11th Nov 2020 8:11pm
Minch90
Thanks Martin Thumbs Up
Just done this and the guide is fab, my only hiccup was figuring out that the hi-low linkage ball joint is a push in to remove!!
Looking down the holes it was amazing how much they seemed to be out of line, so I can see why the collar would help.
Shifting already better, put loads of lithium grease everywhere too.
Carpet almost looks flat as well Rolling with laughter 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #887148 22nd Feb 2021 6:36pm
Niels906
Netherlands
Never mind
Sorry, didn’t read the last persons reply before posting.
Post #935399 28th Dec 2021 3:27pm
giacomo.m
Italy
Thank you blackwolf,
but which bolts are you talking about ?
those of the aluminum box to the gearbox or the 4 torx screws ?
also the adjustment of the gear lever must be done with the assembly of the 2 spacer bushes ?
Giacomo
Post #967234 10th Oct 2022 11:20am
The screws identified in the diagram in step 45 in the WSM extract.
That's the idea. Thumbs Up
Post #967241 10th Oct 2022 11:57am
giacomo.m
Italy
thank you
but the problem is to find the 308-561 tool, and to know how it is assembled and used ....
Giacomo
Post #967246 10th Oct 2022 12:39pm
blackwolf wrote:
... In theory you need to use a locating device when refitting the lever, although I've never found it necessary.
blackwolf wrote:
...I usually pinch up the housing, check for gear selection, and adjust and repeat as necessary until everything feels good, and have never had a problem.
The plastic tool really isn't necessary.
Post #967252 10th Oct 2022 2:50pm
Page 4 of 5 <12345>
