Home > Tdi > Glow plug not igniting on key on
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey friends. So my 89 defender has always had a hard time starting and I finally had a tech look at it and they said the glow plug is not igniting in key on. The glow plug ignites on ignition / starter position?? So tons of un burned has is ending up in the chamber because the glow plug is only turning on when the key is in the starter position
Any ideas would be super helpful. 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #966830 5th Oct 2022 11:53pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Good job your in California as it would be a real issue in colder climates. Mr. Green Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #966837 6th Oct 2022 9:17am
Martin
Site Admin
Is it a Tdi (with a glow plug relay-timer) or a pre-Tdi (TD or NA) without a relay?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #966839 6th Oct 2022 9:26am
jst
Change feed off ign2 to glow plug relay. You are getting glow plug on with starter as glow plugs stay on for short while afternstarting with 300tdi anyway.
Change initial relay feed supply. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #966841 6th Oct 2022 9:33am
Soulrider911
The engine is a 2.5 turbo diesel “Falcon” according to vin. 1989 Defender 90
Post #966883 6th Oct 2022 3:42pm
Martin
Site Admin
OK, on the pre-Tdi there is no glow plug timer, so you have to do it manually!
There is a sprung key position between "ignition" and "start" on the key - this is the glow plug heat position.
Hold the key against the spring before you get to the start position (this is the heat position), count to 10 or 15 or 20, then turn it further to turn the starter motor.
You should get the choke warning symbol come up on the warning panel when you are in the sprung 'heat' position.
Source: my 90 used to be a TD Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #966885 6th Oct 2022 3:50pm
Soulrider911
Ohhhhh! I think I have been doing it wrong. Also my glow plug indicator light might be burned out as it is not illuminating… but I think it is one bulb I have not replaced. I usually turn the key all the way to acc let it sit then try to start. I think I have been doing it wrong. I will try this. Thank you so much, had no idea. 1989 Defender 90
Post #966889 6th Oct 2022 4:09pm
Soulrider911
Just talked to my tech and seems he did test this…
“ I did that check thinking mybe there was a set detent in the switch but never seen voltage to glow plug until engine is cranking over. We will check that when we get the rig back in.”
Thoughts 1989 Defender 90
Post #966892 6th Oct 2022 4:39pm
Martin
Site Admin
Check the switch is wired up correctly, many aren't.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #966893 6th Oct 2022 4:41pm
Soulrider911
Thanks, I have a service manual and can dig into this more… but do you know offhand where the switch is? Is it part of the ignition column in the dash? 1989 Defender 90
Post #966901 6th Oct 2022 5:23pm
Martin
Site Admin
It's mounted on the column, you should be able to see it and the wiring to it if you remove the instrument binnacle.
You're looking for a thick brown with red stripe wire for the glow plugs, the starter wire is white with red.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #966902 6th Oct 2022 5:25pm
