Home > Td5 > Aftermarket AC |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
What about this?
https://www.lrparts.net/da2342r-land-rover...tment.html |
27th Sep 2022 7:27am |
Or this, I just saw you are in Switzerland, your 110 is perhaps a left hooker??
https://www.lrparts.net/da2342l-land-rover...tment.html Give it a couple of days for the currency to be further devalued and it'll get cheaper and cheaper! |
27th Sep 2022 7:32am |
IIRC all of the aftermarket TD5 AC kits are made by CoolAir Logan: https://www.coolairlogan.co.uk/land-rover-air-con
I have this kit on Miffy and it works well and looks OE. One benefit is that it will fit behind a standard Defender non-AC grill if you want to retain the flat front end. |
27th Sep 2022 11:32am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 943 |
As above check out coolair (OEM supplier) and also look at Ministry of defender kits…
https://ministryofdefender.co.uk/buy-puma-...category=0 Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
27th Sep 2022 5:59pm |
A.Rubio Member Since: 04 Mar 2017 Location: Rocafort -Valencia Posts: 32 |
29th Sep 2022 3:18pm |
