Home > In Car Electronics (L663) > Pivi pro 3.3.0 |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
Just set 3.3.0 away to install, looks like there are quite a few changes in this release
Click image to enlarge Name: OS 3.3.0 Estimated installation time: 0 h 45 m Included in this release are performance enhancements to the Pivi infotainment system along with stability improvements to Amazon AlexaTM, Apple CarPlayTM, Android AutoTM and connectivity improvements. This release also includes a number of new and improved features. What's new: - Additional options for assigning to the steering wheel favourite button (diamond icon) Available options vary by vehicle specification and model year. - New control added to the navigation home tile to allow easier back and forth switching between Pivi Pro navigation and Apple CarPlay / Android Auto navigation apps. - Revised start-up/shut-down experience: Welcome screen shown earlier and touchscreen remains on for longer after vehicle shutdown to allow settings to be changed at end of journey. Additional controls available via the Pivi speech recognition system: - Heated and cooled seat control e.g. "Hey <wake> set passenger seat heating to 2' - Place of interest support improvements e.g. "Hey <wake> I'm hungry" or "Hey <wake> find a coffee shop near me" - Turn navigation voice guidance on/ off e.g. "Hey <wake> voice guidance on/off" Navigation improvements: - Improved Pivi Pro navigation experience for commutes. - View traffic on your commute in the homescreen navigation panel. - ETA (estimated time of arrival) information added to the homescreen and Interactive Driver Display when in a commute. - General commutes performance improvement including 'auto start commutes' - Personalised Routes - With the system having learnt your regular routes (Learn My Routes enabled in navigation settings), Personalised Routes (enabled in navigation settings) will aim to incorporate the roads you know best into your journeys towards regular destinations. - Enhanced Smart Voice Guidance experience (enabled in navigation settings along with Personalised Routes): Provides voice guidance only on the sections of your route you are less familiar with e.g when traveling towards home on roads you're familiar with voice guidance will automatically mute. If diverted on to unfamiliar roads, voice guidance automatically unmutes. - Waypoint information is now also shown in the home tile. - 11.4 and 13.1" screens only: More effective use of the available screen area used by the navigation support panels. General Improvements: - Improved calibration for wireless charging when used with Apple MagSafe devices. - Multiple UI/UX improvements. - Multiple usability enhancements to the USB media interface. EV vehicle only improvements: - Select the preferred minimum charge level (charge comfort level) the navigation system uses in planning charging stops. - Improvement to the accuracy of the predicted range when a destination is set. - The recommended charge level when arriving at a charge stop is shown for longer. - Significant performance improvement to the range map (shown only when no destination is set). - Charge Station Brand Filters. From saved destinations, you can now access the list of 'Providers Preferences' and select your preference for each brand from preferred to avoid. Searches for charge stations will then be ordered accordingly. IMPORTANT NOTES: - Live Apps such as Weather & Parking (where available) will be deleted as part of the update. These are typically automatically downloaded and updated on the next available journey (subject to connectivity). - PHEV / BEV vehicles only: Please disconnect the vehicle charger and ensure the vehicle battery has a minimum charge level of 25% before starting the update. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
21st Aug 2022 3:26pm |
and it's installed
Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
21st Aug 2022 5:43pm |
Dicky1961 Member Since: 25 Mar 2022 Location: South Yorkshire Posts: 145 |
Mine says that it’s down loaded new software too the car.
This is a 1st for me. I’ve tried umpteen times to install it but it fails every time. When I go to check, it says loading and then did not install the update. I’ve tried using the car’s system and I’ve tried with it connected to our Wi-Fi . It says install should take approx 45 minutes. I’ve left it various lengths of time, I even left it over night. No joy!!!! |
22nd Sep 2022 2:39pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
My TD5 says to just use the bigger hammer…..
22nd Sep 2022 4:22pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Try taking it out for a short drive - your battery might be a bit below par. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
22nd Sep 2022 4:33pm |
Cheers Tim,
Already tried more than once mate. No joy |
22nd Sep 2022 4:56pm |
nowrxo Member Since: 10 Sep 2015 Location: None Posts: 79 |
It might be worth watching a few PowerfulUK videos on YouTube, as they had lots of weird problems in the past as well:
(Possibly skip directly to the third one, as they did get it installed eventually, if memory serves.) You could also try emailing them, as Simon might be able to give you a few pointers. |
22nd Sep 2022 7:42pm |
Thanks juwivive,
I’ve just been and tried out all the stuff from Simons videos. Not worked on mine. Gunna give the steelers Call see what they say. |
23rd Sep 2022 2:29pm |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 103 |
When I had this problem I rebooted the Pivi pro and took the car for a decent run and it then worked
23rd Sep 2022 2:43pm |
I’m doing a 220 mile round trip on Sunday so I’ll try again after that.
23rd Sep 2022 2:50pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
Downloaded and installed on mine the other day. It did say something about the speed limiter not being available though. 24MY 90 D250 HSE, Tasman Blue
23rd Sep 2022 7:39pm |
220 mile round trip, software installation still didn’t work. |
26th Sep 2022 6:59pm |
Slight bug with mine, or maybe it’s not, but when I switch it off and get out the radio stays on, doesn’t do it all the time but don’t recall off it doing it previously.
One thing I’d like to see in future updates is the radio station logos rather than just a picture of a mic. 24MY 90 D250 HSE, Tasman Blue |
28th Sep 2022 7:21pm |
Taking mine to stealers next Tuesday to let them sort out 🤞
28th Sep 2022 7:37pm |
