![]() | Home > Tdi > TDI 300 Defender alternator bearing failure again |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
Dust,
How many miles between failures? |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 506 ![]() ![]() |
Maybe wrong belt fitted over tensioning and overloading the bearing, there are two alternator pulley sizes used on 300TDI and therefore two belt sizes. Using the shorter belt with the big pulley means the tensioner is under full spring tension
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 839 ![]() ![]() ![]() |
Could just be duff alternators?
It is easy to replace the front bearing yourself and the rear cup/needle bearing can also be found if you are lucky. I have a set sat in the drawer just in case. Did have a couple of bad ones from Paddocks a few years ago. I think I bought the Lucas ones and two failed in quick succession. First one failed electrically then the replacement lasted until just outside the warranty before the bearings died. Paddocks agreed to replace it and I swapped manufacturer (Densa I think 🤔). Same alternator but this one has now done a few years with no issues. If you are killing them regularly then maybe try a different manufacturer. I wouldn't expect dust to affect the bearings as they do have seals, but mud and water might shorten the lifespan. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
I had three alternators within the space of a year on a 200 tdi. The problem turned out to be the wiring FROM the alternator. 1982 88" 2.25 diesel
