![]() | Home > Td5 > Bolt type please |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1450 ![]() ![]() ![]() |
Hi, the screw type is a Button Head Socket Screw.
Thread diameter and length can be measured from your existing ones. Screwfix can supply them in stainless. Typical example, https://www.screwfix.com/p/easyfix-button-...pack/8878t |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
Another option are Black Anodised Aluminium, they be less bling than bright stainless steel :
https://www.pro-bolt.com/aluminium You'll need to check the diameter of the corroded ones, and maybe order washers and nuts to match the bolts. Pro-bolt are not the cheapest, but they are designed for use on motorbikes so are properley outdoor proof, ![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 791 ![]() ![]() ![]() |
Or black stainless steel....
https://www.carbolts.co.uk/?gclid=Cj0KCQjw...J5EALw_wcB |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Now they are a bit nice! Particularly like the etched version ![]() |
Used for the Grill A/C mesh refurb :
![]() Click image to enlarge ![]() Click image to enlarge 3 years now and the Pro-Bolts still looking perfect (the aluminium mesh - not so great ![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Nice
