Home > Puma (Tdci) > Engine light, limp mode |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2010 |
So an explanation of what happened.
So a Diagnostic trouble code, probably one associated with the MAF sensor, would have triggered the limp mode and the check engine light to illuminate as your intercooler hose was loose. These type of DTC’s are being constantly monitored, so as you rectified the loose pipe, restarted the engine and drove the vehicle a while the monitoring showed the issue was no longer their and the engine ECU cleared the DTC , the check engine light extinguished and limp mode was not triggered again. Within you ECU the DTC will likely be stored as an historic DTC. Last edited by Ianh on 10th Sep 2022 1:58pm. Edited 2 times in total |
10th Sep 2022 1:43pm |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 |
Thanks for the behind the scenes explanation
10th Sep 2022 1:55pm |
