![]() | Home > Technical > Replacement battery |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 459 ![]() ![]() |
Hi,
On the recommendation of other members on here I recently went for one of these YBX5019 Yuasa Silver High Performance Car Battery 12V 100Ah HSB019 tayna.co.uk It is spot on, may be in my head but it seems to start up much better too. Delivery was quick and faultless. ![]() Last edited by ChrisDefender on 8th Sep 2022 11:33am. Edited 2 times in total |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
The factory fit is a "dual purpose battery" flooded wet cell, made by Varta, very similar if not the same as their LFD90 after maerket model. That has been superseded by an enhanced frame battery (EFB) who's part number I can't recall.
For normal use, a starter battery from any of the name brands will be fine. If you have a lot of extra accessories I would look to getting another dual purpose battery. Don't be tempted by an AGM battery for starting duties, they offer no benefit and may have shorter life as they need chaging characteristics. 2007 110 TDCi Station Wagon XS |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2262 ![]() ![]() |
I concur with Bluest.. see my post at bottom of this topic https://www.defender2.net/forum/topic16605...p;start=30
I posted this on the 22nd May 2022 and the battery has performed perfectly since then, noting my Defender Puma 2.2 sometimes has several weeks between use. The acid test will be a few cold weeks in winter where I have not started the vehicle. I think a dual purpose battery also pays dividends if you don’t have the facilities to trickle charge during the winter months and the vehicle is not started for several days.i can trickle charge so for me it’s a belts and braces approach, noting that the ALM module CH serial number can suffer a brownout and die if the main battery is significantly drained while vehicle is let standing for days / weeks.
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
I'll link to another post, again a user with a 2.4 Puma : https://www.defender2.net/forum/topic82362.html
I know there is an argument of Enhanced Flooded (EFB) vs Absorbed Glass Mat (AGM) with lots for comments for and against both flavours of battery. I've had a Varta G14 AGM fitted, had zero problems with it. Yes it is slight more expensive, but the peace of mind of not having liquid sulfuric acid in a plastic container under the passanger seat scared me ![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 157 ![]() ![]() |
At my last service, in March, the (independent) garage said that they recommended that I replace the battery in my Feb 2014 Puma before the next winter. They also said that although the AGM is now recommended by Land Rover for the Puma they hadn't seen many that lasted beyond 4 years. No prizes for what I'll be replacing the original lead-acid one with. Cheers, Guy.
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 931 ![]() ![]() ![]() |
Halfords sell the Yuasa batteries - more than up to the job. Not cheap, but very well recommended. 2008 2.4 110 Utility Station Wagon XS.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
This is the same one I have, and this is no a placebo I feel the same way and on paper the specs are actually an upgrade from the factory fitted spec. Not a massive upgrade but a small upgrade all the same. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 Last edited by custom90 on 20th Sep 2022 2:59pm. Edited 1 time in total |
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
Thanks all.
I went with the YBX5019 Yuasa |
👍🏻 WeWillWin🇬🇧🇺🇸
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
I have had my Defender 90 Puma for 5 years so far without a battery change......
When not being used I do keep a Cteck charger connected. Is 5 years pushing my luck????? Cheers Don. |
Reading your other posts your Puma is 13 years old, so if you’re still on the original battery it’s done really well, but if it’s been trickle charged regularly then that’s unsurprising as it’s the deep discharging that impacts wet batteries most.
If on the other hand it’s a genuine battery but only 5 years old, has been trickle charged regularly and starts first time in the winter when left a couple of very cold days without charging then it’s still performing well and won’t need replacing for a few more years. Also if 13 years old you will have the 10AS alarm unit which is not hit by the brownout caused by a low charge state battery, so the worst case is the battery will start to fail and at that point you replace it. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
My 2007 Defender is still running on its original battery. Prior to COVID it was used daily, throughout COVID, when it was not used for long periods, I left a CTEK charger connected. In the post COVID era it is no used as much as it was pre-COVID and I connect the CTEK if I am not going to be using it for a week or more.
I have no idea how long the battery will last, but I am already impressed. It is a lack of use which kills batteries, batteries in vehicles in regular use will generally last much longer. |
Dirky4316 Member Since: 30 Sep 2022 Location: Worthing Posts: 14 ![]() ![]() |
Can anyone recommend a charger to get and from where please? I've just changed my original battery for an Exide was so surprised when it started immediately! Thought I was in a new defender😂
Ctek is generally the go to make on the forum , MXS 5 for most, MXS 7 my choice, MXS10 for a few.
https://www.ctek.com/au/battery-chargers-1...gLODfD_BwE Do online search for best price. |
