![]() | Home > Maintenance & Modifications > New Fox shocks not what I hoped for |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 145 ![]() ![]() ![]() |
Speak to Paul Jones at Prolinx about getting them revalved. He worked magic on the ones fitted to my 100" Bowler. The ride is compliant at low speed on bumpy surfaces but it handles like a sports car when pushed hard on the road.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
Monotube shocks are inherently harsher. I recommend std LR oil (only) or Koni Heavy Track. Puma 110" SW
BIMbound Member Since: 09 Jan 2021 Location: UK Posts: 44 ![]() |
Interesting tip, thanks MR - actually this who supplied them I'm pretty sure. I didn't know that re-valving was a thing 2007 TDCi 90 XS |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1989 ![]() ![]() ![]() |
That’s odd, I had a remarkable difference when I fitted new standard springs and the fox 2.0 shocks, I also fitted the Airlift kit to the rear for when full with expedition gear.
The difference was night and day compared to the original set up. Do comfort springs lower the height? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Yep - that's the beauty of Fox (and imitators) in that they are a rebuildable and configurable component. Mine had flutter valve stacks fitted to give the compliant low-speed ride. Bear in mind that I have quite old-tech emulsion dampers but the principle applies to the IBP (Internal ByPass) type in a similar manner. When initially setting up the Fox on my 100" we did a drive with Paul as passenger to establish a baseline, revalved the rears and did another test-drive then revalved the front. Exceptional change and a much better return on investment than tuning the engine. |
