![]() | Home > Td5 > Steering wheel replacement |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Momo Tuner fitted - replaced a Momo Quark - replaced original XS steering wheel.
All had various pros and cons but I personally prefer the latest (which might be kind of obvious…) Quark had a nice shape and dimension, but felt a bit plasticky because it was er plastic (pvc). Tuner seems like a logical upgrade to the original leather clad LR offering. Also fits in with the black and silver thing going on in the interior. ![]() Click image to enlarge |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2991 ![]() ![]() |
That looks good
You could also do a lot worse than fit an OE XS leather covered wheel. lf yours is 48 spline these are plentiful for around £100 However if like mine it's a 36 spline you've got more of a search on your hands. l eventually found a new one for £280 and l don't regret spending the money. lt's so much nicer than the standard rubberised plastic one. |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 512 ![]() ![]() ![]() |
That wheel looks great, is it just an alloy wheel centre cap stuck on in the middle for the LR badge? I’m not normally a fan of the large empty boss cap but this covers it nicely. Cheers, Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5832 ![]() ![]() |
It’s a plastic centre cap that I “machined” “turned” a recess in, so that a badge would fit in the recess.
By machined turned, I spun it on a hand drill, and removed the material by gently applying a wood chisel ![]() ![]() I no longer use it as went across to a quick release wheel, so it’s just in the garage somewhere. |
