![]() | Home > Camping, Caravanning and Holidays > Suitable Clip On Towing Mirrors |
Bundy Member Since: 21 Sep 2020 Location: Cheshire Posts: 98 ![]() ![]() |
I managed to get normal Milenco mirrors to attach by clamping up from under the mirror arm.
I changed it from the pic to have the tightening bolts at the front as they hit the roll cage when you opened the door. You have to pull the arm out to the 90 degree notch too. I did tie-wrap the clamps on to make sure they didn't fall off....did about 700 miles without any issues that way. Cheers Al ![]() Click image to enlarge |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2297 ![]() ![]() ![]() |
Hello notxal
I did exactly the same as Bundy although with our Eriba at 2.1M wide I have towed without these additional mirrors as even with tight fixing there remains an annoying vibration resulting in semi-blurred rear views. ![]() Click image to enlarge What your aiming for is... ![]() Click image to enlarge A viable alternative are replacement 11.5 Inch Extended Length Mirror Arms at around £40 each ![]() Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2186 ![]() ![]() ![]() |
We have an "extra wide" 8' caravan and have a set of the widest Millenco mirror & arms which as above we clamp frm underneath to fit
I also installed the 90deg swivel head fixings to the std mirrors so I can have a smaller extension when towing narrower stuff |
