Home > Td5 > 110 CSW Body Rebuild |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 756 |
I'm just coming to the close of this process myself..... Nothing difficult, but quite time consuming if you are as fussy as me 😊
If the front footwells need doing then that a welding job, everything else is bolt in or spot welded. Spot welds are easily drilled out and can be replaced with pop rivits. |
29th Aug 2022 9:30am |
Titan133 Member Since: 30 Dec 2016 Location: Dorset Posts: 46 |
That sounds encouraging. Maybe my winter project then. ——————————
2004 110 TD5 |
31st Aug 2022 9:02am |
Gives you a bit of time to make a shopping list
31st Aug 2022 11:18am |
