Home > Maintenance & Modifications > Anyone fitted air suspension to a Defender?
Page 4 of 4 <1234
Mo Murphy
The panhard rod goes between the chassis and the front axle, as you change the height, you change the relationship between the two.
50 Shades of Pennine Grey
Post #963258 29th Aug 2022 1:04pm
blackrock
United Kingdom 2012 Defender 110 Puma 2.2 SW Firenze Red
Ah, I suspected something like that. I'll realign the wheelfor the normal driving height.
Post #963261 29th Aug 2022 1:24pm
Raising and lowering the vehicle will have a similar effect to lengthening and shortening the drag link. I would completely expect the straight-ahead wheel position to change by a small amount between extremes.
Post #963284 29th Aug 2022 5:37pm
jimbo55
Andrew, the wheel position will change with the height of the suspension that’s perfectly normal, set the steering wheel straight in which ever setting you drive most on the road. For me I drive most in sport which is 1”lowered and set it to that so when I go to off-road or normal the wheel does move out of centre slightly
Post #963293 29th Aug 2022 6:22pm
blackrock
Thanks for the replies, I was beginning to think that I'd somehow put the steering wheel on wonky a few weeks back. I also use the slightly lower setting for normal driving so I'll set the wheel straight on that setting.
Andrew
Post #963302 29th Aug 2022 7:44pm
blackrock
jimbo55 wrote:
Yes I have a VB kit, I do find the lights on the controller a bit too bright so always have the controller face down to stop any glare on the windscreen
I've just been reading the VB user manual and apparently you can adjust the brightness of the LEDs on the controls. A short press of the service button with the spanner on it, followed by the up and down arrows that should adjust the brightness of the LEDs.
I'll try this next time I'm in the vehicle.
Andrew
Post #965381 18th Sep 2022 11:17am
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
blackrock wrote:
As a mad idea I was wondering if I could build some electric spring compressors that compress all four springs on command. All I'm after is a temporary lowering of the vehicle, I'm not after the smoother ride that is advertised (a lot). Presumably the bumps stops are reachable with a compressor, as they must be reached at times. I'm not sure it would bother the springs too much, maybe they wouldn't like being compressed repeatedly, and the mechanics would be interesting to say the least.
Andrew
In the US rock crawlers sometimes have "suck-down" winches to pull the axle into a full (or near-as) bump condition to improve stability on climbs and descents.
Post #965484 20th Sep 2022 7:15am
jst
We used our rear winch as a suck down winch for Croatia trophy terrain at times.
Anyone fitted irb suspension, or had it fitted? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1034776 14th May 2024 7:36pm
Page 4 of 4 <1234
