Home > Td5 > MSB flashable ecu |
Matteo Member Since: 27 Aug 2022 Location: italy Posts: 11 |
Hi to all, i'm Matteo from Italy and i have spent some times playing with td5 ecu and this is the last project i've develop.
Basically i've mod a msb ecu and develop a kit that transform it in to a NNN flashable ecu. https://youtu.be/n37nh2A18uI |
27th Aug 2022 3:26pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6102 |
Good work Matteo!
27th Aug 2022 5:58pm |
thank you mate
27th Aug 2022 8:11pm |
hi, the msb converted run with 000120 firmware so you could upload all maps for def and d2 10 and 15P, and the kit will be dual map. for cruise i've still to test, i'm waiting for d2 auto msb ecu for testing all under my d2.
29th Aug 2022 10:53am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 625 |
For cruise check, it it sees all switches - for cruise and for clutch. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
29th Aug 2022 11:51am |
right, i can see them on nanocom
30th Aug 2022 8:03pm |
Excellent!!
31st Aug 2022 4:54am |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 660 |
I can send you a D2 auto MSB ecu for testing if it can be sent back afterwards. Let me know if that’s of use. Steve |
31st Aug 2022 5:00am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2852 |
This would be a great product if you are able to manufacture it. The Defender/Discovery ECU's are starting to give trouble and new ones are around £2,000 from Land Rover
31st Aug 2022 6:58am |
thank you mate, i'm waiting for a little batch of ecus that have to arrive in this day |
3rd Sep 2022 1:10pm |
but there in uk you can buy nnn for 200gbp... problem is here in italy that nnn cost a lot... this is the reason of that mod. |
3rd Sep 2022 2:36pm |
You can't buy for 200GBP, Discovery Auto maybe but not Defender
l paid 700GBP for my 2005 Defender TD5 ECU a few months ago. lf anyone's selling these for 200GBP l'll take all your stock |
4th Sep 2022 10:24am |
mate sorry but where have you take the ecu? on uk fb market nnn are from 200/300 gbp max... if you are lucky you can find someone 200gbp shipped inside uk.
discovery auto are good too, not plug and play but with some mod you can mod it into manual ecu, i've did it for many years. 500250 are good too.... change the firm with 500020 and you can put it into def or d2 10p and 15p |
4th Sep 2022 2:03pm |
done today i have mod the cruise control circuit on a msb000080... nanocom show that criuse set and resume switch are working... |
4th Sep 2022 3:38pm |
