Home > Puma (Tdci) > Brake Fluid Change
Page 2 of 2 <12
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Re: Brake Fluid Change
rob369 wrote:
Hi one and all, can anyone advise as to whether 1 litre of brake fluid should be sufficient for a routine fluid change on my 2.2 90 tdci or should I buy 2. THANKS
Hi, may I know if 1 litre was sufficient? Thank you APK
MY2016 110 Adventure Corris Grey
MY1997 110 County Station Wagon 300 Tdi Alpine White
Post #962974 26th Aug 2022 2:36pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Hi APK.
One litre will be more than enough.
Post #963025 27th Aug 2022 12:42am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Agreed 1ltr is ample and as mentioned already I also frequently use a large syringe and draw old fluid directly out of the reservoir to add fresh. Doing this frequently on my cars and bikes just becomes part of my routine maintenance and is easy. Thumbs Up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #963027 27th Aug 2022 4:58am
Dinnu
Do you simply open bleed nipples one caliper at a time and let gravity do the work? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #963028 27th Aug 2022 6:07am
APK
piechipsandpeas wrote:
Hi APK.
Just to confirm that is to replace entirely, not just refresh?
Thank you! APK
Post #963052 27th Aug 2022 12:52pm
piechipsandpeas
Yep that will be more than enough to bleed the line at each of the 4 calipers and have the reservoir full at the end.
Post #963055 27th Aug 2022 1:29pm
Page 2 of 2 <12
