Home > Pictures & Video > Puma anti-stall
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Puma anti-stall
Definitely a real-world scenario this - towing a 12T truck with no driver.
http://www.youtube.com/watch?v=0jhuKLrjJLg&feature=related
Quite fun though. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #9617 10th Apr 2009 10:17pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
That is quite amazing Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #9625 11th Apr 2009 9:16am
philp
2008 Defender 90 Puma 2.4 HT Tonga Green
I often wonder after being impressed with the Anti-stall on my TDci if it would be an easy thing to re-programme the engine management strategy on the TD5 to give the existing rather poor Anti-stall a bit of a boost?
I assume the ECM does this by adjusting the Fuel delivery/Injection control to compensate for the sudden load,
so you would have to re-write that part of the strategy to really up the Oomph... we know in tuned form the TD5 is quite capable of impressive torque figures.
Any thoughts anyone?
Post #9632 11th Apr 2009 3:05pm
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
that was an amazing peace of video. am i correct in thinking that the antistall is also know as idle jack? Cheers
keith
puer claudius
Post #9988 21st Apr 2009 7:52am
AndrewS
No, two different systems. the idle jack is there to help, stop or reduce the engine braking in low range. The Puma has lots of Torque (too much) when you need to use engine braking to descend, the standard engine would hold the wheel rotation back and the vehicle would slide. The simple fix was to increase the revs when the clutch is lifted in 1st low, This now allows the wheels to turn at the same rate as the vehicle descends. Not an exact science but LR decided that an idle jack is better than no idle jack. This is what happens when an engine from a parts bin is adapted for use in a vehicle that it was not designed to be installed in. Thanks Ford Rolling Eyes Twisted Evil
Post #10039 21st Apr 2009 9:11pm
mse
Not really - more like when the design and redesign is cost limited or time limited...its not beyond the capability to change that problem...the cost will have stopped it. Mike
Post #10072 22nd Apr 2009 3:37pm
AndrewS
Wink Ahh Whistle well you clearly know the proper answer Thumbs Up From your answer I expect you know more than you are letting on Thumbs Up
PS
Will the new one work 'Please say yes'
Whistle
Post #10116 23rd Apr 2009 8:03pm
