Home > Maintenance & Modifications > Helping sourcing/ID'ing a few pieces...
J1990
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Tamar Blue
I'm hoping some of you may be able to assist with ID'ing and/or suggesting a good source for a few items that I'm needing to get my 2.4 110 ready for some trips before we say goodbye to her.
Item 1 - We've managed to lose the screws which attach the sun visors to the roof. I had ordered some from LRParts (CYP500140) but quickly found that the ones provided were significantly thinner. I can't for the life of me find the correct dimensions or a part number in order to get another set ordered.
The below image shows the screws I'm trying to replace and I apologise for the quality/angle!
Item 2 - Looking to replace the swivel housing on the nearside front, MOT failure this morning says it's the pin and bush that are worn but regardless of selling her I think the decent thing to do here is stump up and pay for the full thing replacing so that it's sorted for the next owner. Is anyone able to confirm that part DA3180 is the correct item for a 08 Puma 110 with ABS? (VIN SALLDHMS79A769450 if it helps)
Item 3 - Rear exhaust is knackered and the centre is on its way out. Again, I'd like to replace both so that the job is done. Just wanting to replace like for like here but I know nothing of exhausts and have no idea if fitting a cat-delete could cause issues. I'd welcome any suggestions on where to source a suitable replacement for this.
Final point is really just looking for some advice. The wing tops have got black checkerplate on, evidently it had worn a little and a previous owner just painted over the top. I want to get this cleaned up and looking good for the next owner, would it be worth drilling off the rivets, cleaning it all up and repainting? Is it viable to paint it whilst still fitted? Easier to just order some replacements?
Thanks in advance!
Post #962244 19th Aug 2022 1:28pm
