Home > Technical > Wiring in diff lock 1988 vehicle
jst
After some wiring advice please.
I have a 1988 e reg 90 that has had a number of items replaced along the way, gbox, bulkhead, some wiring etc.
The diff lock switch is not connected to anything on the transfer box. There is no loom there.
Diff lock works.
There are no obvious wires terminating that should go to the difflock switch from the dash indicator bulb.
For ease I would like to run a new wire from the dash indicator bulb to the diff lock switch.
What colour wire should I be connecting this wire too? I believe this then switches to earth to illuminate the bulb when thendiff lock is engaged.
Ideally looking to pick up feed off the back of the white multiplig that connects to the tell tail indicator bulbs.
I will run other terminal on t box switch to earth.
Any help appreciated. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #961851 16th Aug 2022 10:47am
Linds Hanson
Black/blue from light to switch and earth from other side of switch to one bolt on transfer box high low selecector.
Post #961854 16th Aug 2022 10:52am
jst
So black and blue wire from back of dash indicator bulb? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #961879 16th Aug 2022 2:06pm
Mo Murphy
Yes, to the switch. Then black from switch to earth.
50 Shades of Pennine Grey
Post #961995 17th Aug 2022 1:48pm
jst
Cheers for confirming Mo. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #962064 18th Aug 2022 12:12am
jst
All sorted this afternoon. Even found the original blue and black wire on the chassis rail, shame it had been worked into the fuel sender! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #962204 18th Aug 2022 11:17pm
