Home > Maintenance & Modifications > Triangulae plate that holds rear crossmember |
Defendertomten Member Since: 19 Aug 2020 Location: Avesta Posts: 48 |
Anyone that knows whether the triangular shaped with a triangular hole in and rounded endsupporting rear crossmember upper is available to buy? Im removing the rear crossmember and cut the left one before i saw that its not welded on, on my new. Or is it just to fabricate one or find a scrap rear crossmember to get it from. My reat end chassi is looking good so im hopefully going to exchange just the crossmember. Land Rover owner since 2003
2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
11th Aug 2022 4:48pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I am not sure if RTC3354 is the top or the bottom reinforcing plates, or if it is actually a full kit, such as this: https://www.ebay.de/itm/303985401568
No affiliation with the seller. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
11th Aug 2022 7:17pm |
Thank you very much for the tip. I have mailed them.
Regarding my crossmember change, i dont want a cut off and welded on a joint when its only my crossmember thats bad. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
16th Aug 2022 10:29am |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
I've just bought a part from DDS (the crush tubes for the ends of the crossmember). They're primarily a business to business supplier but they will sell retail - its just a bit slow in getting a reply. I struggled by email but calling them direct saw the part delivered the next day - so if you don't get a reply by email, don't dispair and just give them a call.
16th Aug 2022 1:20pm |
Yes, I'll give them a call tomorrow. Btw. How thick is the chassi from start?Steel quality? Its a bit corrosion in the rear from cabin to the end. Flake rust. Don't know the english word. So i have to measure the end steel if I have to exchange some parts in end of the chassi. I want it to be safe to tow heavy with it. Land Rover owner since 2003
17th Aug 2022 5:47pm |
2mm 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
17th Aug 2022 7:33pm |
