Home > Puma (Tdci) > loss of power after changing injector seal
nicolas0505
France
Good morning all
I had my injector seals changed on a Defender 2.4. Since the change I have had no power, no torque, very slow acceleration. I checked if I had any fault codes and none.
Post #961349 11th Aug 2022 2:51pm
HardCharger
Were the injectors returned in proper order? If not, the ones that are out of place are most likely not working.
Any strange noises?
Post #961387 12th Aug 2022 4:02am
nicolas0505
France
the injectors were put back in the same assembly order.
apart from that one of the cleaning, it seems that debits more like before. I have a small hole at one point when I decelerate at a certain moment in neutral. apart from the vcv which must be a little tired
Post #961401 12th Aug 2022 8:27am
