Home > Maintenance & Modifications > Side Step moulding?
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Side Step moulding?
Hi All,
The rubber moulding on my 110's side step has come apart (pic below). I've been searching the usual parts suppliers but couldn't find just this replacement part. Surely I do not need to buy a whole new replacement side step. Any idea's?
Chris
Post #961233 10th Aug 2022 11:44am
They're really not available separately, unfortunately. If you're lucky, you may find a set of rusted out steps that the rubber can be salvaged from but beyond that it's new steps, I'm afraid.
As a stop gap, you may get away with taking them apart and then refitting the rubber so that the damaged edge is inboard. Depends how far gone they are, though. Darren
Post #961236 10th Aug 2022 11:47am
ChrisCSL
Thanks Anorak,
Was afraid that was the case. Curse my big feet. I can try and remove and glue the torn bit. As you say fitting the other way around inboard is a good idea 👍
Chris
Post #961237 10th Aug 2022 11:53am
