Home > Technical > Salisbury Diff Pinion Seal |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Morning all,
About to change the diff input flange and seal on my disc braked salisbury rear axle following shotblasting and painting. I have bought a new 'OEM' flange kit which comes with seal. The branding of the flange and seal is 'EAC'. Normally I would not entertain fitting anything but Corteco seals but it seems the choice of brands for these seals is fairly limited. From most of the suppliers EAC seems to be one of the more premium options (other options being unbranded or britpart gamble). Do people think the EAC one is usable? The price of a genuine seal is £60-70 so certainly not fitting that! Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Aug 2022 9:14am |
Fair point cheers, will stick the EAC one in. Not looking forward to having to mess around resetting the bearing preload with the new flange!
10th Aug 2022 6:25am |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 143 |
What about using a speedysleeve and seal from an engineer's merchant?
10th Aug 2022 8:50am |
