Home > Td5 > TD5 Sitting for nearly two years. |
LeebertTD5 Member Since: 06 Aug 2022 Location: Perth Posts: 2 |
Hi gus, looking for some advice.
I have a 2004 TD5 Defender 90 that I owned whilst living in Italy. When the spicy cough took over I decided to return back to my home country Australia. I had no idea how long until I could return to it. Long story short it has been sitting there with the battery disconnected and very low fuel for almost two years. I am returning to Italy this week and hope to drive her. My question is, what if any problems will I encounter after having left it sitting for so long? Also are there any steps I need to take before I start it for the first time? Thanks in advance! |
6th Aug 2022 11:25am |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 865 |
Expect a long list of: tyres will have flat spots, change fluids, drain and refill fuel tank before bio contamination reduces all components to mush etc.
It's a Defender! Check tyre pressures, fill tank with fresh diesel, charge battery, start it up and drive away! I didn't touch my Morgan (NOT the most reliable of vehicles) for 18 months during COVID, took the dust covers off and it started at first spin of the starter. BUT, in anticipation I'd fitted a battery disconnect switch so there was no drain through alarm, clock, radio etc. (quicker than removing the battery, on my 4-seater one has to jack up the rear, crawl under the car, and disconnect and unfasten the battery to manoeuvre it over the back axle). Just go for it... Peter |
6th Aug 2022 11:54am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
If power in the battery run pump prime after checking engine like level. Then turn the key drive it to a fuel station and fill it with good quality fuel. Then give it an oil change and a set of filters when you get a moment.
6th Aug 2022 12:13pm |
Thanks, guys. I have a new set of filters, wheels, and tires waiting for me so will get into it as soon as I arrive!
6th Aug 2022 1:01pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2758 |
Any update on this, did you get the Land Rover started?
10th Aug 2022 7:15am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Maybe it had rusted away?
11th Aug 2022 4:58pm |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 |
pop some injector cleaner / diesel max into tank and top up to full.
change fuel filter and cycle purge a couple of times, then run to temp and blast on motorway, should be all good. expect bushes to request they arre worn out after a month or so of running, if the they have sat for a bit, |
2nd Jan 2023 8:45pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Not sure on the OPs outcome but for others interested I would unplug the crash switch on the bulkhead and turn it over a few times to get the oil round without it firing 2002 90 Td5 Station Wagon
2nd Jan 2023 11:45pm |
