![]() | Home > Puma (Tdci) > N Type tow electrics |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Are the N type tow electrics plug and play or plug and pay dealer to activate ?
Simon |
Thanks
Yup, as bpman says, get the correct LR Part (number LR005920), and it just plugs in to the car. All the electronics work straight away (such as the dashboard light shaped like a green trailer telling you the indicator on the trailer is working).
Up under the drivers side rear wheel, right at the back, above the crossmember (on a 110, best to lie on the ground with your head behind the back wheel) there's a feeble plastic flap with 2 screws - the connector is under there. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
if you do get a new one take some time to waterproof it when you fit it - I used vaseline on all the pins/connectors. My original had corroded badly, the wires were all black so rewired using marine grade cable. Should hopefully stem corrosion for a while.
Thanks..
My 130 not due until March but accumulating a pile of parts for it. Simon |
I meant to add, the genuine ones have gloopy silicone sealant over the socket end but I managed to take the other end apart and fed the wires through the rear of the x-member.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
?? Funny,, all mine i have fitted, the plug when through the X member hole ok ?? no need to take apart ![]() Main Brian James Trailer Dealer for South West UK |
Tim, you must have some bigger holes in your rear x-member or simply more talented than me at hole manipulation ![]() |
