Home > General & Technical (L663) > P400 vs D300
abyss
Australia
P400 vs D300
Hi All,
What is your experience on both engines?
I’ve driven both back to back. I found the in gear acceleration is stronger in D300 but it felt heavy.
P400 doesn’t pull as strong as D300 but it revs all the way and felt lighter and more nimble.
I’m quite confused after driven both. I know diesel would be more fuel economy.
Post #959946 29th Jul 2022 11:10am
brucehun
South Africa 2003 Defender 110 Td5 DCPU Java Black
If you are going to tow then the D300 is a must.
Post #960179 1st Aug 2022 8:37am
lightning
lt depends. Who wants to buy into diesel now? l've got a 90 Commercial in order and if it could be specified with a petrol engine l would happily put up with the compromises when towing our caravan.
ln fact l am currently debating whether to go ahead with a diesel vehicle at all. How long before they are hammered for tax? Diesel is already more expensive than patrol and some cities charge more to park if you are in a diesel vehicle.
Post #960249 1st Aug 2022 6:52pm
Logannz
New Zealand
I've driven both, and both drive extremely well. The choice largely comes down to your locality, Here in New Zealand diesel is a simple choice especially if you tow due to the way road and fuel taxes work here.
I have a friend with the P400 and the fuel economy really drops with any weight behind. I suspect too that real world fuel usage probably favours the D300 due to the way they drive. The P400 really loves you putting your foot down.
Personally I plan to order the D300 when the time comes (ie when my Disco V8 is due to be replaced)
Post #960268 1st Aug 2022 11:10pm
brucehun
Maybe for the UK and Europe but for the 'real' world diesel lives😁
Post #960287 2nd Aug 2022 10:34am
haymeister
Japan
In Japan, diesel is 20% cheaper than premium unleaded.
Factor in better fuel consumption and an easier drive with all that torque then it becomes a no brainer. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #960372 3rd Aug 2022 1:53am
zilch
Australia
In Oz diesel is currently more expensive that both 95 and 98 octane Laughing If you are looking at
Long haul and towing around Oz then yes Diesel is a better choice, dodgy fuel being the main
issue in some outback areas as you would know. I went with the P400 as there were no 6 cylinder
diesels on the horizon when I ordered and took delivery, so will stick to the wagon for our lap
around Oz towing about 3.2t off road caravan. There seems to be plenty of options for 95 in
many remote areas on the main routes, plus V8 Nissan Patrols have been hammering around
without petrol supply issues for quite a few years.. Down to your use / requirements/ choice,
the D300 is a great vehicle to go for.. pity it was not available when I finalised my build in early
2020 yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #960382 3rd Aug 2022 7:03am
