![]() | Home > Tdi > Has anyone ever used the Lucas Transmission Fix in an R380 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3522 ![]() ![]() ![]() |
There was never a LandRover gearbox that was designed for ATF! Rover decided to use ATF to smoothen cold shifting. I hear stories that the bearing suppliers even warned and voided their bearing warranties as ATF is not the best lubricant. Having said that, owners of the LT77 are kind of stuck in using ATF, as any thicker oil will damage or shear the oil pump.
For an R380 I would stick with the MTF. You do not need to add anything else. Regular service interval with good quality oil is more important. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2316 ![]() ![]() ![]() |
Sounds like snake oil to me !
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2234 ![]() ![]() |
In my experience it works very well in addressing certain issues with traditional torque converter auto transmissions. However I would not use it it for Manual box’s or mixing with MTF.
