Home > Puma (Tdci) > RPM not working, Temp Gauge at max, loss off engine power |
DeCA Member Since: 18 Aug 2020 Location: Vlaanderen Posts: 8 |
Hi There, problems in my dashboard and loss and lack /loss of power, due to gauge meters that not working properly, I cannot find a solution. I installed a winch, perhaps wrong???
Puma 2.4, 2007MY |
21st Jul 2022 3:25pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2005 |
As above it does seam a battery connection issue.
When installing your winch have you added an additional negative to your negative battery terminal clamp ? If so it will likely be preventing the clamp gripping the negative terminal correctly and this could be your problem. There is an easy fix for this if that’s the issue. |
21st Jul 2022 4:52pm |
