![]() | Home > For Sale & Wanted > [Sold] Steinbauer power boost module 2.4 tdci |
clifflandy Member Since: 13 Mar 2014 Location: Lichfield Posts: 109 ![]() ![]() ![]() |
A plug-in boost module that takes the power output from 121bhp to 145bhp. Extract from the on-line info below:
Landrover Defender 2.4 tdci Original Power: 121bhp Enhanced Power: 145bhp Original Torque: 360Nm Enhanced Torque: 432Nm Part Number: SB-220153 https://www.steinbauer.cc/gb/products/pass...__48e/9X9/ The desired performance enhancement is achieved by changing the injection duration, the same way the system was originally designed to operate. This also allows precise fuel control throughout the full rpm range of the engine. Injection duration is achieved by adding pulse width to a signal, (i.e. at end of injection). This is not changing timing—that’s best left to the factory ECU. The STEINBAUER module also does not interfere with common rail pressure - making the STEINBAUER module the best choice for your engine. Good condition with wiring loom, full instructions and original box. £100 plus postage. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
