Home > Maintenance & Modifications > DRL Schematic with switched 12v source
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey folks, I figured I would share this. I have not been able to find any sort of diagram to aid folks who want to add DRL’s from a switched 12v to their Defender. I have also mocked up here what it would look like to add a Fuse bank with half switched and half constant.
I would LOVE your input here. Does this look accurate? I have dug around a lot in the dash and found a two candidates to use as a relay trigger: the rear window switch, the WHITE Ignition wire. I am inclined to use the Ignition wire.
The only pain is it would seem I have to run wires under the cab in the engine bay and though the firewall… though, should not be too bad.
Welcome any and all thoughts, consideration and criticism Very Happy
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #958787 19th Jul 2022 12:19am
