Home > Puma (Tdci) > What is behind this dash location? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
The heater matrix sits behind there. From memory it’s pretty tightly packed.
18th Jul 2022 5:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
There is a little room but is is very limited no more than 1”, less and less lower a little more at the top edge but the heater matrix is curved.
If you really do want to use it take the centre dash out and measure up precisely. In fact measure twice to be sure. You may find there just isn’t enough room but it isn’t too difficult to remove the centre dash. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Jul 2022 7:51pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 568 |
Click image to enlarge There's quite a lot of space behind the 'X' and it's easy to get to one the centre section is pulled forwards. Just undo the two bolts on the front of the dash and then pull it free from the top edge. |
19th Jul 2022 9:41am |
