Home > Maintenance & Modifications > Best place for rattle can paint?
Co1
Any thoughts on the best place for rattle can landy paint. Metallic if that matters.
Col
Post #958413 15th Jul 2022 11:44am
ibexman
Your local car paint factor can usually knock up some paint and lacquer for you in a rattle can
Post #958414 15th Jul 2022 11:58am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
I agree with Ibexman. My local motor factors mix the paint themselves in aerosols. Their metallic paint water based but no issue as long as you have a hot air gun to force dry it before applying lacquer. One major benefit I've found over the stuff you get at Halfords is the quality of the spray nozzle. Proper fan spray rather than a useless cone pattern and you can turn the nozzle through 90 degrees to get a horizontal or vertical fan. Not quite like spraying with a proper gun but the next best thing.
Post #958415 15th Jul 2022 12:24pm
Gasket
I get a lot of Corroless pain from ArcEuroTrading. Not available in metallic though.
Alternatively there are now the relatively new 2k aerosols specifically those with Air Dry Converters. These are “2 pack paint aerosols” which have a ring pull on the bottom to mix the hardeners, but they don't use isocyanates so don't carry the no-DIY issues that have surrounded traditional 2-pack paints. But a far better, more durable finish than normal autofactor paints
There's a few firms that mix them up, here's one: https://www.yourspraypaints.com/faq-items/...ray-paint/
Post #958418 15th Jul 2022 12:52pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Gaskets suggestion sounds a good idea a 2k paint is way better.
But definitely go to a paint supplier and get the colour code mixed up in a can.
Avoid any of the off the shelf stuff rubbish paint and rubbish spray pattern/finish.
I use Brighton Paints for all my stuff
Post #958420 15th Jul 2022 12:57pm
Gasket
just reread my post.
To be clear Co1, I haven't used one of the fancy aerosols yet - I should have been more careful with my 'But a far better, more durable finish than normal autofactor paints' -comment. That's what the marketing says, but not from first hand experience.
Post #958421 15th Jul 2022 1:00pm
Dinnu
The problem with the 2K rattle cans is that it is a one time use.
A small air compressor (I use a 50liter one and I find it as more than enough) and a decent spray gun will be a lot cheaper if you like to paint the occasional part and want good quality material and finish.
As long as you do not mix the hardner with the paint, the paint shelf life is very very long.
And with the air compressor you can inflate tyres, dust off difficult areas... uses are practically endless. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958423 15th Jul 2022 1:12pm
