Home > Puma (Tdci) > Turbo Issue
110DCRoss
United Kingdom 2007 Defender 110 Puma 2.4 XS DCPU Java Black
Turbo Issue
I was driving along today and there was a sudden pop noise followed by a whoosh of air that sounded like a tyre popping but then I noticed a lack of power. Now when I accelerate above circa 1800rpm the turbo makes a load whine a bit like an electric motor and also whistles very loudly. Checked both hoses (2.4 TDCi) to and from the intercooler and no leaks. Had my mate ride on the wing with bonnet off and it’s definitely coming from in and around the turbo area. Any ideas?
Post #957950 11th Jul 2022 8:33pm
Spilt intercoolers are depressingly common but so are split hoses that only manifest when under load. It's just a case of methodically checking every component of the intake system, unfortunately. Darren
Post #957956 11th Jul 2022 9:03pm
110DCRoss
I’ve had both hoses off and inspected them and removed the air-con RAs to inspect the intercooler. The noise is definitely at the turbo.
Post #957959 11th Jul 2022 9:11pm
Check the hose below the turbo it can rub on the steering column as they are surprisingly close.
You are talking under half inch close if you are lucky or closer.
Check the turbo actuator rod moves freely with it disconnected from the electronic actuator and a little light oil on the pivots.
What you have described sounds like a boost leak or overboost, though the latter if the actuator gets stuck on full boost will usually trigger limp mode and a DTC but won’t necessarily trigger the amber light on the dash.
Could be the IC instead as LRA mentioned, if you get stuck I’d get advice from a LR specialist as they see these things all the time.
Often they’ll take 2 mins to look at it and go, yep we’ve got another one of those and all done.
Failing that they’ll know the tricks of the trade and or have equipment to test these things instead.
If you have capability to read DTC’s then I’d definitely recommend you do and look the code up.
It might just well tell you the culprit, or give you clues possibly instead. Chillin In The Backwoods🇬🇧🇺🇸
Post #957961 11th Jul 2022 9:33pm
Check the gasket between the turbo and exhaust manifold (a common failure) and between the manifold and head (a slightly less common failure).
Post #957964 11th Jul 2022 9:54pm
