Home > Technical > Brake Light Switch Cover |
blackrock Member Since: 01 May 2022 Location: Hampshire Posts: 57 |
After refitting the cover and checking the rear brake light operates correctly using a tell tale LED on the high level light, it looks like it must have been a wire or some other item holding the brake switch closed. It's worked perfectly since I refitted the cover.
20th Jul 2022 7:37am |
