![]() | Home > In Car Electronics (L663) > Navigation Settings - Problems |
MHE15 Member Since: 25 Mar 2022 Location: Midlands Posts: 32 ![]() ![]() |
Hello Hazelhunter. Did you get a fix for your problem. I have the opposite problem. Car shows distances in kilometres on sat nav but miles on speedo. I cannot find how to get sat nav to use miles. Thanks.
Michael |
Hazelhunter Member Since: 18 Nov 2020 Location: Hohenlohe Posts: 19 ![]() ![]() |
hello Michael, yes I got a solution.
You have to change the basic settings in the main menu of the vehicle a few times. From miles to km/h and vice versa, leave the menu every time. then the navigation system takes the appropriate settings. Much luck ! Hazelhunter |
Thank you. Will give that a try.
