- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
JohnGr
My 2009 Puma is having starting probs again.
This time it will start from cold in the morning, go out for a drive, pull over stop the engine and it may or may not start - it won't crank, nothing there at all. It will bump start and once cooled down will start again ok.
My thoughts are the starter motor solenoid sticking, but I believe you can't buy the solenoid on its own, just the whole starter. Another thought is would the temperature sensor or water temperature sensor cut it out... is this possible?
Any thoughts anyone?
24th Jun 2022 7:52pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
