Home > Other Site Sponsors > Futuranet Puma Gauges Controller
Page 2 of 2 <12
Martin
Site Admin
Thumbs Up
Just ask if you have any questions
Lots of progress made in the last few months with this, including the launch of the system controller which integrates air con control, ABS/traction and more! Plus a load more supported engines - but a 200 Tdi is easy, one of the first we did Wink
https://www.fnltd.co.uk/shop/puma-system-controller-p114.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #851085 20th Aug 2020 9:59am
oneten10
Turkey 2004 Defender 110 Td5 DCPU Keswick Green
Re: Futuranet Puma Gauges Controller
I have 2.2 defender puma cluster, can I use that cluster with my td5 puma engine+original td5 wiring loom . Thanks.
Post #861729 15th Oct 2020 12:31pm
Martin
Site Admin
Yes definitely!
If it is a Defender Td5 ECU you are using, then you need:
Defender Td5 controller: M.501
Td5 loom adapter: H.501
This gives you a setup like this:
You may need the rev counter wire adding from the ECU to the Td5 speedo plug: W.551  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #861730 15th Oct 2020 12:36pm
oneten10
Thanks Martin , for your quick reply,
what the difference, 2.2 cluster vs 2.4 cluster? my service said me "2.2 cluster will not work , buy a 2.4 cluster."
if You sure it will work, could you tell me the price of your gauge controller. how can buy , can U send to Turkey?
Post #861739 15th Oct 2020 1:12pm
Martin
Site Admin
2.2 and 2.4 have different CAN messages, and normally use a different fuel sender (2.4 is the same as all previous Defender sensor).
But we fully support both 2.2 and 2.4 clusters on a plug-and-play basis with our looms. I'm 100% sure it will work!!
More details in our web shop: https://www.fnltd.co.uk/shop/puma-gauges-controller-c18.html
Any more information you need just ask!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #861744 15th Oct 2020 1:57pm
mkenya
Kenya
Any idea when these will be available again?
Post #956005 20th Jun 2022 11:10am
ibexman
PM inbound
Post #956009 20th Jun 2022 11:46am
Martin
Site Admin
Later this summer I'm hoping to get a product back on sale again. It's been an utter nightmare with chip shortages - not even just limited in availability, absolutely zero availability since mid last year.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #956010 20th Jun 2022 11:50am
Page 2 of 2 <12
