Home > Td5 > Warranty Tips for a new owner - what should I look for?
3216andy
United Kingdom 1999 Defender 90 Td5 Heritage LE Atlantic Green
Hello one and all, I'm new to this forum and also yesterday took ownership of a Heritage 90 CSW in Atlantic Green.
I have a limited warranty on this vehicle and it will be going back on Monday as driving home, a 20 mile trip, the engine felt liked it misfired at @3000rpm and then the engine warning light came on. This has cleared this morning, but I have not driven the vehicle today. I also found a bolt hanging out of the bell housing.
Are there any common faults (or should that be how many) I could check for before returning to the dealer, the vehicle has done 57,0000 miles.
Post #95597 22nd Oct 2011 10:57am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
get the dealer to sort it all out and if necessary consider an independant assessment from someone like the AA.
bolts hanging out would really worry me. has it been serviced/repaired competantly?
is it a TD5? BM52
Post #95601 22nd Oct 2011 1:03pm
3216andy
It is a Td5, I just spoke to the dealer, it's just had a new clutch fitted, that would explain the bolt hanging out, but it's not a good advert for their workshop.
Post #95602 22nd Oct 2011 1:07pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Could be the wading plug?
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #95609 22nd Oct 2011 1:45pm
3216andy
We've just been out in it again, hit 3000rpm in third and felt like hitting a wall as the engine cut out momentarily and the engine light came on again.
Post #95617 22nd Oct 2011 2:24pm
bm52
maybe a faulty MAF BM52
Post #95621 22nd Oct 2011 2:53pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi,
Most likely the wastegate actuator, it is probably sticking and not fully opening causing a fuel cut due to overboost.
The engine usually makes this around 2750-3000 rpm, does on mine anyway.
Look here
Mine does it all the time, give it a good vigorous working as in the video. It may stick again though after a while. Not sure if it is the turbo wategate or the actuator which is the problem.
Give it a go
Steve
Post #95623 22nd Oct 2011 4:35pm
shazzy90
hi the heritage model was a 2000 year i belive with 57k on the clock this seems to be very low milage ,and with this milage it should not have needed a new clutch ,unles it has done 57k towing a drilling rig/caravan or had a hard life ,as for the misfire i would suggest oil in the loom a very common fault in td5 of this age
Post #95698 22nd Oct 2011 10:07pm
3216andy
Worse today then ever, back to the dealer asap, I'll let you all know the outcome.
Post #95800 23rd Oct 2011 7:04pm
wslr
If the bolt is out, it could be a botched clutch change. The crank sensor reads off the flywheel and is mounted on the bellhousing - the flywheel is on the engine. if you are getting a crank sensor misfire, then I'd suggest the gearbox is not where it should be.
Either walk away, or if you really want it, get an independent to take a look and get the seller to foot the bill.
It should have been done properly the first time. This suggests it was done on the cheap by the seller.
Post #95801 23rd Oct 2011 7:09pm
3216andy
I've just had a look, there is oil in the loom, limping along to dealer tomorrow.
Post #95972 24th Oct 2011 2:24pm
BigRuss
Exhaust manifold warping,
You've got a way to go before this happens, you just start to hear a whistling and lose some power. Best fix is to have the warped manifold machined flat. Sticking a new one on will just warp in the same time frame as the first but the other won't warp again. Russell
2011MY 110 XS USW Black
Post #96006 24th Oct 2011 4:29pm
3216andy
New mass airflow meter, new injector loom and new crank sensor, now runs great. Very Happy
for the moment Whistle
Post #97546 1st Nov 2011 5:27pm
