![]() | Home > Puma (Tdci) > puma 2.4 lots of obd fault codes |
Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 68 ![]() ![]() ![]() |
hi
wondering if anyone can help at all as im a bit overwhelmed by the number of fault codes that are being picked up by my nanocom. if anyone can offer any suggestions as to what i could be missing from the vehicle as well/ other ideas as im in the process of rebuilding the defender so havent ever heard it start up. i have attatched the photos of the fault codes on the nanocom below. cheers Last edited by Sam smith on 11th Jun 2022 7:23pm. Edited 1 time in total |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
ok thank you for the reply. any ideas which wires in particular as i have attempted to go through them before but there are so many that i just end up getting lost in them. they are all still out from the bulkhead so if there were some colours to follow that would be great.
cheers |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 872 ![]() ![]() ![]() |
Post removed, just noticed that the truck hasn't yet been tested
Peter |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
You've read codes but what actual faults do you have?
You need to finish the rebuild/refit (from an electrical point of view), then clear codes and try again to find the actual issues. ![]() ![]() |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Is this the defender that you bought without an engine and have been sourcing parts for?
Have you got it running now? Given that it has been heavily worked on it could be anything. Are you 100% certain that all parts you have fitted are compatible with each other? Are the engine, engine harness and ECU matched to each other or sourced independently to one another? > 110 XS Double Cab |
as far as im aware everything electrical that should be connected is connected. The issue its having is that it will crank either once for one cycle or not at all. it is as though something is cutting it off
hi
no still not running and yes very much an ongoing project. the engine and engine harness came together from one vehicle and the bulkhead, ecu, clocks came together from another vehicle. as far as im aware they are all compatible though i could be wrong as i am definitely no mechanic. |
