![]() | Home > Tdi > LT230 Intermediate shaft O rings |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
FRC8292 at the large end, FRC7439 at the small (threaded) end. As far as I know these are the same for all LT230s.
Classic110 Member Since: 14 Mar 2021 Location: East Yorkshire & Hertfordshire Posts: 25 ![]() ![]() |
Thanks blackwolf (again). Managed to just order them from my local supplier, will be here tomorrow. Fingers crossed it will be all ready to go back in tomorrow afternoon. I took the sump cover off to check everything and it all seems in fine fettle, no visible apparent cog wear or rubbish in there.
Remember that if you remove the intermediate shaft and your box is one with a collapsible spacer on the intermediate gear bearings you will need a new spacer (typically £1 to £4 aftermarket or £
![]() If you have a box with a selectable, non-crushable spacer you can simply reassemble without this need provided you haven't changed the bearings. I *think* that a TDi is likely to have a crushable spacer, a TD5 or Puma should have a non-crushable unless it's been rebuilt before. |
Yes it has the crushable washer, also ordered. I took a pre load measurement before removing anything so I could use this for re-assembly, no new bearings. I found a good video on the net that showed how to do this without the expensive tool.
Good stuff, just wanted to make sure you were aware because you don't want to find out about it when the old spacer drops out!
Your pre-dismantling preload may be a little reduced due to wear, but if you can reset it to the same afterwards you should be fine. The LR procedure tells you to assemble then pull up the nut until all end float on the intermediate gear is taken up but there's not yet any preload. Then with the box in neutral measure the torque needed to turn the input gear (on the box I built up last week this figure was 8 lbfin). Then tighten the nut until the necessary torque increases by 10 lbfin (so I set mine to 18lbfin ). Of course this only works if you can actually measure the torque, if you can't then you more or less have to use some before-and-after comparison method. |
So today I have put the TB all back together and ready it is ready to go in the 110. The WSM states the following oil for the TB:
Transfer box LT230T API GL4 or GL5 90 EP MIL - L - 2105 or MIL - L - 2105B 80 EP C or D However there is a lot of references about not using GL5 as it corrodes! I have enough for a dry refill in the shed of EP80/90 GL5. Is this OK to use? |
TB back in used GL5 in the end.
