Home > Technical > 10AS Alarm and Nanocom on 2010MY USW 110 |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
To eliminate the volumetric sensor you can pop it out of the trim panel and unplug it. The previous owner of my Td5 did this as he left his dogs in the vehicle and didn’t RTFM to work out how to deactivate it.
Try this, if your alarm continues to misbehave you need to look deeper. |
12th Jun 2022 12:17am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2100 |
Have you had a look at the 10AS unit to see if it has got wet due to water ingress? It would be worth removing it to give it a close inspection.
To do so remove the drivers footwell speaker and look up and you can see it. Remove the two connector plugs and see if there is any moisture or corrosion on the pins etc, then remove the two screws holding the 10AS to enable it’s removal and inspection. |
12th Jun 2022 9:41am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
So firmware update on the Nanocom enabled reading of 10AS.
Only event was "volumetric sensor open" Have disconnected it and turned alarm on (by locking with keyfob) Is there any other way to test the volumetric sensor? |
12th Jun 2022 9:51am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
Open one of the windows, lock the car with the alarm set, then (once the alarm has set which takes a few seconds) stick your arm through the open window and wave it in front of the sensor.
Alarm activation = working sensor, no alarm activation = faulty or disconnected sensor. |
12th Jun 2022 9:59am |
Thanks Mr Wolf
Sounds obvious now when I read what you have said!! A new one is £321 inc VAT Also whilst it may well work with something in the car ( can always leave the dog in there), the fault it is exhibiting is it is being activated when I am not expecting it to be (have removed spiders from the vicinity) |
12th Jun 2022 10:05am |
Over 6 hours with volumetric sensor unplugged and no false alarms !!
12th Jun 2022 3:34pm |
