![]() | Home > Td5 > Rear springs - which way up? |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 546 ![]() ![]() |
Plastic bits at the top otherwise you wont get the spring retainers in at the bottom.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
Cheers. 1999 Defender TD5 110
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Also with the weight of the vehicle on them it is likely the tighter coils will be spring-bound so having them at the top prevents the build up of any muck/detritus at the bottom of the spring
![]() Steve 02' 110 TD5 Double Cab Rebuild Thread |
